Hi all,
I just had a Honeywell ST9400C installed into my home yesterday, and I have a newbie question that hopefully someone will be able to answer.
Basically, with our old controller, we never used the timer and switched it on and off whenever we wanted to. With this new ST9400C, is there a way we can do the same, i.e. not use any of the three daily programmes and just switch on/off the hot water/heating as and when?
Having read the manual, I'm guessing that we could just set the mode to Auto, set the three daily programmes to off (by having each start/end time match), and then use the override button to turn it on/of manually?
Or alternatively we could set the three daily programmes to off and switch the mode between On and Off when we want it on and off?
Does this make sense? Hopefully someone with some knowledge of the ST9400C has an answer!
I know I should move with the times and use the programmer, but I like to be in control!
Thanks in advance for any/all replies!
