Newish electric boiler not producing hot water - any help?
5 Dec 2008
Cheshire
Hi folks,
First time poster, not sure if anyone can help on here?
Live in a new build flat (3 years) old, recently the electric boiler (range tribune) which is connected to a Horstmann Electronic 7 controller has stopped heating water.
The off peak settings are still setup and the red light indicator comes on to indicate the programme is running but no hot water.
I can't even get it to heat, even when the manual "boost" button is pressed, again red light shows it should be working.
Has anyone out there experienced a similar problem and who would be the best tradesman to contact - a plumber or an electrician?
Thanks in advance for any advice offered.
