Hi There
I have been asked if i can wire so as to shut off the power to a socket circuit when the fire alarm goes off .
I am thinking to do this by installing a contactor next to the DB and switch it from the fire alarm panel .
I know that the panel has a normally closed circuit in it and a common but i don't know if there is a voltage present across the contacts , or if i need to feed on to the common etc .
I need to know this so i know what voltage coil i need in the contactor .
The job is too far away just to go and test this so i was wondering if anyone knew or if they knew where i could download the manual .
The panel is a NL5704 from newlec .
Cheers
Jeff
Cheers
Jeff
