    Dismiss Notice
Newly plastered wall dry?
Discussion in 'Decorating and Painting' started by Ambernewbie, 23 Feb 2020.
  1. Ambernewbie
    Ambernewbie
    23 Feb 2020
    16
    Thanks Received:
    Country:
    Sounds a stupid question but how do I know when a newly plastered wall is dry please? Is it when the wall is a light pinkish colour?
    Also I know I need to paint on 2 coats of mist is it best to use a roller or brush?
    Also can I use any old emulsion like B&Q own brand or do I have to use Dulux emulsion?
    Really sorry about all the questions but never painted new plaster before and I have gone to the expense of having it replastered so really dont want to make a hash of it.
    Many thanks
  2. Sponsored Links
  3. Chris_W
    Chris_W
    26 Sep 2019
    3,015
    Thanks Received:
    807
    North
    Country:
    Post a photo.
  4. sparkwright
    sparkwright
    20 Aug 2009
    7,380
    Thanks Received:
    900
    Dorset
    Country:
    Be certain to dilute your emulsion to the correct ratio for the mist coat. If you don't, it can peel off and you will NOT like it.
    Roller will give a better finish and coverage for this mist coat.
  5. sparkwright
    sparkwright
    20 Aug 2009
    7,380
    Thanks Received:
    900
    Dorset
    Country:
    Light pink plaster, and no dark damp patches.
  6. Ambernewbie
    Ambernewbie
    23 Feb 2020
    16
    Thanks Received:
    Country:
    What is the ratio please?? I have read a few different posts and they all say different. Alos can I use the B&Q own brand please?
  7. opps
    opps
    16 Jun 2006
    4,177
    Thanks Received:
    631
    London
    Country:
    The ratio will be printed on the tin. Dulux Trade is normally 9 to 1, ie add 10% water by volume.
    BTW you only need one mist coat. If you need to filler and sand after the mist coat, then spot prime with the mist coat mix.
    I have never used the B&Q own brand paint. I stick with trade quality paints, although they cost more they are normally better at covering and therefore reduce labour costs.
    • Like Like x 1
  8. Ambernewbie
    Ambernewbie
    23 Feb 2020
    16
    Thanks Received:
    Country:
    Thank you Oops - will be using Dulux - prefer to spend a bit more and have a good job.
  9. Sponsored Links
Loading...
Share This Page
