The details for Nickel–metal hydride battery and Nickel–cadmium battery are on Wikipedia and the problems in charging the Nickel–metal hydride battery is highlighted.Nickel Cadmium or NiCd rechargeable batteries are now restricted to medical and military use in Europe because of the heavy metal used in their construction. They also suffered from low capacity and a memory effect. Their replacement NiMH rechargeable batteries do not suffer from these drawbacks.
Seems I was not too far out with my off cuff answer.The charging voltage is in the range of 1.4–1.6 V/cell. In general, a constant-voltage charging method cannot be used for automatic charging. When fast-charging, it is advisable to charge the NiMH cells with a smart battery charger to avoid overcharging, which can damage cells and even be dangerous. A NiCd charger should not be used as an automatic substitute for a NiMH charger.
My main charger
