Had a sparky doing some electrics, including a fused spur running off a ring main. He left the fuse out of the spur plate (ring main behind it) while I finished off work.
When I'd finished and came to to push the fuse in, I got a big BANG and spark/smoke and it tripped the consumer unit RCD. First time I've seen this, pretty scary.
On investigation, it looks like he'd nicked the insulation through to a live core on the ring main and when I pushed the fuse in it was enough to push that live core against the metal box at the back - the red core is slightly blackened either side on the nick.
I'd prefer to cut out the damage but I've tried pulling on the twin and earth and there's no spare, so it would leave the cable quite short/tricky to reinstate.
Am I OK to bind up the nicked core with insulation tape and/or cover with heat shrink tubing? If it's much more than that I'll have to get him out again, but given the complete pigs ear that company have done of some LV downlighters (three melted connector blocks, said they'd checked the rest, I didn't believe they had and indeed - two more gone brown, one of which was split with the metal connector inside badly split in 2 places...) - I'd rather not let them set foot anywhere near where I'm working ever again.
So, any wise person know the approved way of fixing a mains nicked core in a back box (single, space is tight)?
Many thanks.
Many thanks.
