Night latch no longer needed. What to do?
17 Dec 2018
I have a night latch in a composite door which we no longer need and we are using the euro cylinder below this exclusively
If i remove the night latch there will be unsightly holes in the door.
What can i do to disable the night latch but still have the door look somewhat normal
fill the hole with a wooden plug, which you can make by using a hole-cutter in a scrap door or piece of wood of the same thickness, glue it in place with a weatherproof glue such as Evo blue bottle
if you cannot fill and paint to hide it, put a brass or stainless fingerplate on the door to conceal it, matching the other door furniture.
https://www.ironmongerydirect.co.uk/search?query=fingerplate
If you want a brass finish, PVD plate on stainless is very durable and needs no polishing.
You can also get a round cover sized to conceal a yale-type cylinder hole, but I do not know the name for them. Like a blank escutcheon.
Dismantle it and take the latch out
Woody is this a easy job for a somewhat competent Diy'er? :D
I looked on YouTube and couldn't find a video on this surprisingly
If i try to cut and fill the hole, i know that I'll make a dogs dinner out of it and my missus when never let me hear the end of it..
Great shout on the blank escutcheon. We like that. Thanks
Yes take the lock off and they are just screwed together. You'll see what to do, never mind YouTube.
Screwdriver - unscrew the latch part from the inside of the door completely, usually just three screws into the wood. Under that, held by a couple more screws, is the actual part that the key fits into undo the two screws and that will come off too. Then use you chosen method to fill it, if you decide to do that.
Alternatively you could instead, just jam the latch permanently internally - so the door no longer latches and refit both parts.
