Night storage heaters and economy 7
1 Dec 2010
Surrey
I have night storage heaters on economy 7. They are meant to come on at 12.30am and heat for 7 hours which is fine. However, I leave the wall switch in the ON position and the red light comes on at the switch. I was wondering if it should do this when the night rate is not in place. I also noticed tonight at 8pm that the big one in the lounge is making a humming noise, does this mean that it is charging outside of the night rate? Im worried that in this cold spell I am paying peak rate prices and my heaters are constantly on charge.
Please help as Im am becoming worried about the bill as heaters have been switched on at the wall for 6 days!
Many thanks
Assuming they have been installed correctly, and your metering has been installed correctly, they should only operate during the off peak hours. The red neon should only light during those hours.
What sort of timeswitch do you have at your meter, an old clock type or is it a "black box" teleswitch, if it is a clock it probably has not been reset for a while and is working at the wrong times, you should be on off peak anyway as the timeswitch also switches the meter over to off peak, a pic of your metering arrangement might help
