Nightmare staircase help needed please!
2 Jun 2007
Manchester
I've a DIY teaser for you here! :D
I've been without a bannister/handrail for ions now and the time has come to replace it.
I've a few problems before we do this! :?
In his infinite wisdom, the long gone ex sawed the bottom post down to half its size, and sawed the whole of the handrail and the wood underneath it so all we have left is the stump of the post and the bottom where the wood staircase went. (image where the spindles would go - well this was a solid piece of wood).
I believe that the minimum spindle width we can get it 32mm, the base where the wood went is 25mm :? the only option I can see is to remove the bottom stump Question 1 - how not sure as its seems to be joined onto the bottom step, and Question 2 find some sort of wood that can be used instead of spindles, to completely encase the stairs. Another problem is where the wood was has been Polyfillered in so I imagine that would have to be dug out for the wood the lie in?
If this makes any sense whatsoever, I'd appreciate any info as to how to go about this!
Susie
Hi it sounds to me like you just have a baserail left with the narrow groove size, I would suggest replacing this baserail that sits on the top of the stair string (stair side) with a new one with a standard groove size, or put a new one on top of the existing with a standard 32mm groove size.
There is a reason you cannot buy 25mm spindles/balusters as standard this is because stair balustrading components now have to meet new standards - 0.36KN is the impact rating they need to meet.
As for your newel post you can buy turned newel posts that simple slot into your existing post.
You can purchace stairparts From places Like B&Q - Homebase - Tradestairs.com and many more.
Just an idea.
Lee
