Nilfisk pressure washer - drain & tube cleaner problem
25 Nov 2004
Hi, I have just bought a 15m drain and tube cleaning hose for my Nilfisk Pressure Washer. When I connect the new hose, the pressure washer runs for about 5 seconds and then cuts out. I have to release the trigger and wait for about 10 seconds before it will start again. 5 seconds later it stops again. This continues all the time I try to use the new hose.
When I go back to the standard lance, it works fine.
Something to do with the new hose?? I know it is designed to go around tight bends but it does seem VERY flexible.
Can anyone throw any light on this please?
It could be that the main is not supplying enough water to keep the pressure up or the opening at tip is too large to work with your machine.
Pressure washers rely on back pressure in the lance to work effectively. I'd suggest the accessory isn't designed for that machine or, as mentioned above, the incoming water volume and pressure isn't sufficient.
John :)
Hmm, thanks for the quick comments. That's annoying, the water pressure is very good here so I suspect the machine is not man enough for the task!
The machine is actually borrowed so I may have to buy (or borrow :rolleyes:) a larger one. It's a Nilfisk E140.2 - any good?.
I'm sure it will be very similar to most pressure washers of that price range - but I'd only choose it if it had the drain clearing accessory that you need, then you have some comeback if it's not suitable.
John :)
