Hi I have no 250v power to the pump on my jaguar 23 combi boiler
the boiler hot water side is working but the pump does not run
the room stat is set to call for heat but there is no power getting to the plug on the pump, I have checked the fuses on the pcb and are both ok
the pressure in the system is at 1.5 bar. Is there anything else I can check? can anyone help with this fault please, thanks mallxx.
