No BT master socket...just an extension socket
30 Jan 2010
Notts
The BT line in my property terminates into what is obviously a secondary extension socket, rather than a master socket. Probably been DIY'd on at some point. Phone lines work fine, broadband works fine. As such, I'm not sure whether to worry about it too much but 1) is it likely to be missing safety elements (i.e. surge protection) and 2) would I notice any improvement in broadband speeds if I replaced it with a proper master socket with built in filters?
Are you positive it's an extension socket? old style (pre NTE5) master sockets looked just the same as extension sockets from the front, the only way to tell the difference is to look at the back.
If it is an extension socket then yes.
It really depends on your wiring layout. Ideally you want.
1: the unfiltered wiring should have no branches and the DSL modem should be at the end of it.
2: the unfiltered wiring should be done in suitable twisted pair cable. Opinions differ on whether cat5 or CW1306 is better but either is far better than cheap untwisted cable.
3: no ringer wires should be connected in unfiltered wiring
4: phones should be connected via a single filter. Wiring after the filter may include a ringer wire to support older phones and may branch as needed to support multiple extensions.
A NTE5 style master socket with a filtered faceplate fitted can help you achive the above while maintaining neat wiring.
The NTE5a socket's primary purpose is demarcation - to allow BT to say this is ours and that is yours.
The surge arrestor was present in the old NTE's, and has been taken out in the latest design - it never stopped lightning damage anyway.
If what you have works, then I'd be inclined to leave it as is.
