I was wondering if anyone can give advice about a promlem that I am having with my heating. As it will be hard to get a plumber out over xmas it looks as if we are going to have a cold one !
We had a new Worcester Boiler. The hot water works find but we have no central heating unless the hot water it turned on, and water is below temperature. So to get the heating on I have to run the hot tap until the boiler comes on to heat the hot water. If the CH is also turned on they both heat up together, until the HW water reaches temperature.
I have a new room stat and controller. The controller is a drayton Lifestyle LP522. I have noticed that there are ony 5 wires to this but the wiring diagram shows 6. Terminal 2 (CW off is unused). This was replaced last year.
I wonder if this is a faulty 3 way valve (Current one a Tower MP3 22C), which I could replace if it were just a matter of like for like with same wiring, and if I can get one on Christmas eve. Do not want all the fuss of draining down the system etc if this unlikly to be the case. Can anyone suggest how I can work out what what to do?
