No CH or HW
15 Nov 2006
Essex
Potterton 60e boiler and CH/HW system with two control valves.
The system stopped heating water, but CH continued to operate. I suspected the power head was faulty and so replaced. The boiler fired and operated for a few minutes when the system was switched back on, but then stopped. I now get no CH or HW. The boiler fan is running, but the pilot is not being triggered.
Any suggestions?
air flow/pressure switch probably
would suggest you get a decent boiler man in now
corgi, had the same problem found it easy to fix after waiting one month for a corgi to fix, dun it with a man who knows a man who corgi, five minutes if that, cost 29 quid.
doyle said:
corgi, does that not cut out both hw and ch together as it does with ariston
helping the learning curve :D
read the post doyle
"but then stopped. I now get no CH or HW. The boiler fan is running, but the pilot is not being triggered. "
if the air flow doodar aint working then the boiler will not work
Thanks for the suggestions - interestingly, the boiler has started working correctly again - a bit weird!
