No cold water pressure
28 May 2006
Norfolk
I live in an extremely high hard water area :( and my cold water supply in the non power shower has totally diminished. How can i defur the pipes :?:
The problem may not be throughout the pipes. What sort of shower/mixer is it?
How hot is your hot water? If it's over 60 odd you will get a lot more limescale problems. Is it an electric immersion heater?
Have you made sure the head is clean?
Where do you live, as a matter of interest?
If you unscrew/undo the rose on the shower(the part that the water actually comes out of), there may be a rubbery bit with holes in that you can rinse under a tap. As you bend the rubber the limescale sort of cracks and falls off. If not at least you can poke through the holes in the rose and that might help. Many weak acids dissolve limescale. :wink:
Thanks for the prompt replies. The shower is a standard hot water feed from the boiler and cold from tank in the loft. The boiler temp is set to 65*. Lower the shower head and the pressure starts to become normal. oh yea we live in north norfolk.
