Think that was a reply to my post rather than the OPMy understanding of the OP's scenario is that he has the two ring cables in his hand at the CU (not connected to the CU) and while there is continuity between the ends of the CPCs and the neutral wires, there is no continuity between the ends of the phase wires. IE there is a break in the ring, somewhere.How would you know there was a fault on the socket circuit if it were a ring?
I got mixed up more with a fault on an older install.
Whereas it seems to be like you say, although i would not class ,that as a fault, more a f*** up, no offence to the OP
