Cheers thank for the reply. Just out of interest what would happen if you used a 13a fuse instead of a 3a?
Yes, that the primary reason for the fuse being in the plug. However, electrons don't know about myths and human intent, so that doesn't stop the fuse also affording some protection to the 'device' connected to the end of the cable.Urban Myth ; Fuse is there to protect the device on the end of the flex. Wrong !! The fuse is actually there to protect the flex between the plug and the device.
As long as the breaker supplying that socket is off then it will be fine. If in doubt, switch off the main switch - it's often not hard to switch off the wrong circuit and I'm assuming you won't have the right tools and knowledge to check the socket is dead.Im still concerned about the plastic snapped off in the socket. If i flick the switch in the circuit breaker im deffinately not going to be fried?
