Hello all,
I have a light which has been run from the house to a connected outside brick built storage area which has a small conservatory built around it. The conservatory has no light and I wanted to disconnect the light in the storage area and run a light to the conservatory from the switch in the storage area. The switch seems to be an old type which has connection for only two wires and no earth connection.
The wires in the switch are as follows.
Two cables running into switch.
Two live red wires wired into Top and Bottom of the terminal.
The two black neutral wires wired off into an isolated connector block.
Two earth wires cut and not connected to anything.
The light in the storage area has been run off a connection somewhere from a light in the house. I can't trace where because the cable goes into the ceiling void but I presume it is from the nearest light which is in the nearest room (kitchen)
My problem is this: The light I am fitting needs an earth. Since the earth wires are cut off at the switch I need to use, I don't know if there is an earth connection at the other end where the light was run off from and I can't find this out because I can't trace it back. Secondly, why are the two neutral wires isolated in a connector in the switch and should they be connected in a new switch which has connections for earth,neutral and live. I have put new lights in the house before and spurred of extra sockets etc without problem but have not come up against this. In the absence of wiring the new light to the switch I can wire it to a plug without cable showing as I have a socket in the storage area but really would prefer the switch.
Grateful for any help/advice that can be given.
