Ok, I think I may have killed my upstairs pump.
You may have seen my previous post about tuning my upstairs heating. The main problem was the radiator in the master bathroom was not heating up.
1. I took the radiator off the wall
2. drained it
3. checked the feed and return values
4. put the radiator back on the wall
5. bled the radiator
I couldn't see anything wrong with it. At that point, I figured out that it was the last radiator on the manifold and that the second last radiator was heated towel rail that was recently installed. So I turned down the heated towel rail (it was very hot) and hey presto! The radiator in the master bathroom heated up .... mystery solved!
Two days later ... and there is no heat in the upstairs at all. When I turn on and off the upstairs pump, the power LED turns on and off also, but there is no whizzing sound like there is from the downstairs pump.
The upstairs feed manifold (shown on the left in the photo below) and the feed to the boiler are both hot, but the return is cold (shown on the right in the photo below). So I presume I have managed to kill the pump somehow.
Was there something I neglected to do after I reattached the radiator to the system ?
2. drained it
