So basically we moved into this house a few months ago and have just found out we can't get the central heating to work unless the hot water is on!
We have an unvented system, hot water tank & pump & 3 port valve in airing cupboard, F&E tank in loft, control panel/programmer, and a thermostat.
If the room thermostat has the flame and CH is on at the programmer, nothing happens. Boiler doesn't fire up. No errors or anything.
Hot water works fine when requested.
If HW is on, then CH will also come on. The 3 port valve A side pipes get hot if CH is requested, and they cool down when thermostat turned down to not request heating. I don't know if this rules out the 3 port valve but the rads will get hot doing this. But if I then turn HW off, leaving CH on, it stops working.
I have changed the motorised part of the 3 port valve but without solving the problem.
Any ideas please?
*The grey wire that is 'loose' came from the very left hand terminal where the single earth is
Any ideas please?
