Hello again folks..
When running the hot water the pin on the diverter doesn't come out. If I push the microswitch manually the boiler fires up but the water still comes out cold. If the pin is triggered by water flow then is it possible something it blocked? Otherwise activating the switch manually should give hot water, no?
I could well be wrong as I don't know anything about these things. Could you advise please?
