no hot water but radiotors okey
6 Nov 2007
Manchester
no hot water but radiotors okey halstead best 60 when l open the tap boiler not light up but when put radiators on evryiting ok can help
As far as I am aware the Best 60 is a heat only boiler so will not fire when hot taps are turned on :shock:
You need to check your programmer and 3 port or DHW 2 port valve.
Search on here for more info.
Subject has been covered a 1001 times :wink:
