Hi, I have a glow-worm fuelsaver F boiler. This morning I discovered that the boiler is not firing up when the timer kicks in , and therefore getting no hot water. I have two independent motorised valves.There is resistance on both valves when overriding them. I have found that if I turn the central heating on, and manually override the hot water motorised valve then, I can get hot water.The motorised valve for the hot water still shows resistance even when the timer is on for the hot water.Do I need to replace the motorised valve? Also if this is the case will I need to drain down the system?The central heating is working fine..
