no hot water coming from bath shower mixer
16 Dec 2008
Staffordshire
hi for the past year its been working fine . today went to have a shower and only cold water is coming through but hot and cold is coming from the mixer taps.can anyone help .the tap is a bath shower mixer
if you have cold coming through the shower the change over lever must be working. could be a block between the hot tap and the shower outlet
yes the shower lever is fine .when i pull it up to let the water flow through the shower water comes out but its cold not warm.the cold tap is off but only cold through when the hot tap is on.when the shower head is in off mode and hot tap is working fine .hope this makes sense
so hot tap gives hot water.
shower, hot tap on but gives cold water.
have you a make/model of tap or pic?
yes thats right its a puzzle. its all been working fine until today.i will find out the make but it was just a normal bath/shower mixer from b and q
