I know this has been brought up many times but I cannot find a cure after searching the forum!
I have a Worcester Bosch oil fired boiler that is regularly serviced. The problem I have is that the central heating is fine but there is no hot water!
The pump is working fine (I'm not sure that is relevant for the hot water) I have a Honeywell two port motorised valve that has two positions, open/manual and auto, I have tried it in both positions to no avail. The header tank in the loft is working fine. There is a bleed pipe in the airing cupboard where the hot water cylinder is, if I undo this nothing comes out, air or water!
Everything was fine yesterday, the only thing I did was bleed a couple of radiators!
Any help greatly appreciated.
Keith
Keith
