No hot water (picture of setup)
Thanks for thhe link, according to that (and also it helped by looking at the inside cover) I have a Sundial Y plan with a V4073(x) valve. So I can test power to it at least and I know a lot more about my set up.
I'll post back. I propose detaching the valve if possible to see if the spring structure is fecked.
If I cant detach it then it's a job for Professional Services,
...and as if by magic the shopkeeper appeared.
Well not quite hot water actually and tons of it. Turned off power to unit. Detached the unit and as I did the spring sprung back. Re-attached with the lever (being spring loaded now). Turned power on, switch on heating 10mins later hot water.
The culprit...
http://imagehost.darkernet.co.uk/i/littlebugger.JPG
Is this a common problem?
A big thanks to everyone who help me with this. I am now a much cleaner person, in body anyway.
