Hi everyone. I have just added a larger hot water cylinder, about twice the size of the old one. It is a vented system, does not contain any air blockages but there is practically no flow coming out of the top, it is just a trickle (0.25 litres/minute). Have tested flow up to cylinder feed and that is fine. I suspect that it may be not enough head pressure from the storage tank (about 2m) to flow through the new cylinder. Do you think this is possible and how should I rectify it. I talked to a pump manufacturer and they sugguested a negative pump after the cylinder and before outlets. This is £300 so do not want to spend it if it is something a bit simpler. Thanks
