Not too familiar with he model but standard cb25 has a microswitch on top of the diverter valve, if you drop the front panel down it is a u shaped microswitch, if you push it up to disconnect from the diverter valve and then make/break microswitch, cant remember if it works when on or off. Try it with just microswitch disconnected and activating the microswitch.
