no hot water
31 May 2011
Hampshire
hi i have an alpha he cb25 that is not heating any hot water but is working the heating any ideas thanks
Not too familiar with he model but standard cb25 has a microswitch on top of the diverter valve, if you drop the front panel down it is a u shaped microswitch, if you push it up to disconnect from the diverter valve and then make/break microswitch, cant remember if it works when on or off. Try it with just microswitch disconnected and activating the microswitch.
thanks have tried that am now pretty sure that is the diverter valve as is running through the heatinh system when i call for hot water,
