No more nails adhesive removal
9 Jan 2023
Hi after putting up some coving in the kitchen
my wife as noticed a few marks on our white kitchen cupboards which are smears of no more nails adhesive. Any ideas how to remove , what to use etc without damaging cupboards.
Solvent free no nails? Solvent. Solvent free and polymer types so which do you have.
hot soapy water and microfiber cloth I'd try first. That's safe.
Next if don't work you could try WD - 40 but spray on microfiber cloth not doors. Rub gently and see if it comes off.
Also test on internal side first as you never said what type of doors you have and WD-40 might effect them.is a good cleaner though
The data sheet says
Immediately remove any adhesive residue with a damp cloth. Cured material can only be removed
mechanically.
Find data sheet here
Id go with hot water and microfiber cloth then
