no revs
5 Feb 2011
Durham
can you help my vivaro will not go past 2000 revs,had egr valve replaced and heater plugs still doing the same ???????????? thanks
Getting it plugged in to read the fault codes should tell you that the crankshaft sensor is faulty?
Or its not getting enough fuel from the tank?
thanks for the help got it sorted . tried egr valve and heater plugs . the problem was the mass air flow sensor i would try that first if it happens again
