Conventional system: CW storage in loft, HW copper cylinder in loft below it fed by 22mm pipe that drops vertically (through 22mm gate valve below tank). 22mm pipe drops about an inch below the level of the connection to the cylinder, goes through a 90 degree slow bend and then rises up to the HW cylinder.
Cock-type drain valve in the 22mm pipe close to where it enters the bottom of the HW cylinder.
Had to drain both tanks due to a leak. Repaired leak. Refilled CW storage from mains CW. Airlocks in HW pipework so blew them out using mains CW from a flexible hose under the sink. Mains CW discharged from HW cylinder through vent pipe into the CW storage and then overflowed to outside.
Now have HW from all HW taps but this stops after a while as the HW cylinder is not refilling. Drained HW cylinder using drain cock on 22mm pipe near connection to HW cylinder- drained OK, some discolouration but no sediment. CW storage tank is plastic and clean inside, no obstruction.
Never had an airlock in this house in 30 years. How do I clear an airlock between CW storage tank and HW cylinder? Is it an airlock?
Thanks in advance for any ideas.
