Hi All,
I have a LogiMax H15 boiler which is a Heat Only boiler. It's worked well since installation and the plumber installed a new pump about a year ago due to a minor issue it had.
It is displaying "Fd" now which apparently means "No Water Supply".
Sometimes it does work though, like two days ago this happened and then for no apparent reason the heating began working. This worked for a day or so and has now broken again.
The pump is on and making the right noises. My boiler has no guages on it. I've switched it on and off a few times but no luck.
We're arranging a plumber, but is there anything I can do in the meantime to at least kickstart the heating or try to fix the issue until he comes?
