Noggins needed or not?
10 Mar 2025
Hi all.... I am putting up plasterboard for my kitchen ceiling.... the plasterboard is running across the joists as its meant to ... the joists all have very random gaps betwen them but none more than 390mm apart.... I am using fire rated plasterboard... is there any reason to put noggins across any of the gaps... The previous ceiling that i took down has none? There are no cut edges anywhere in the room (They are all at the edges of the room). thanks
When I reboarded ceilings I put timber knoggings so that all the board edges had screws through into timber. Stopped any future cracking on joints.
Then you get herringbone struts to hold the timers square.
Or some don't bother with either..
Fire rated board is heavy. Get help or a board lifter.
I used rock wool stuffed in void then chicken wire to hold. Foil backed plasterboard in kitchens..
Brings back memories of me boarding our bathroom. The ceiling took 2 x (8x4) sheets with a thin strip down the middle.
But struggling on my own with a length of T shaped timber at one end and my head at the other, IDK how it didn't all go horribly wrong!
