you remove the fan, insert finger to back left side and press down on plate, it should flex a little bit but if it moves its faulty, also happens on icos and isar models, though not as often. seen a couple like this after a technical help video was shown at work.
Well BG were back today and replaced the Heat Exchanger. Touch wood, no plane noises (yet!)
One thing I have noticed is that the new Heat Exchanger is a bit noisier. It sounds almost like a fan running for about 30 seconds after the water is off and then turns off. I wouldn't consider it an alarming noise, just definitely a bit more audible whirring or buzzing than the previous one.
Is this likely just because it's brand new out of the box? Or has technology changed since 2011 (install date) and this one has something different?
