Noise from cold tank
1 May 2008
When I run the hot tap the tank in the loft makes a noise. Is it the ballvalve? if it is do I just change it. What is wrong. Can anyone help.
probably, yes, worn out
it is easiest and quickest to swap a new one in. you want the brass one with a plastic bridge over the top to spray the water downwards. you can get a repair kit to change the working parts in the old one, but I recommend you do this after you have fitted the new one. then you can put the repaired one in a plastic bag and leave it next to the tank ready for next time.
