Noise from the tank in the loft when water is filling
25 May 2014
I am not a plumber so pls treat me as a compete novice in plumbing.
My room is under the water tank in the loft, the tank makes a lot of noise when the cold water is replenishing. What can I do to stop or drastically reduce the disturbing noise?
I could be wrong but I'm pretty sure those types of valve are only approved for toilet cisterns filled off a tank in the UK. Not for filling loft tanks from the mains. Looking at the link there is no mention of WRAS approval.
What kind of valve do you have at present?
Part 1
http://www.screwfix.com/p/pegler-prestex-float-valve-part-1/90110
Or Part 2
http://www.screwfix.com/p/pegler-prestex-float-valve-part-2/27627
On part 2 valves turning the plastic spout on top so it impinges on the valve / arm itself rather than just pouring into the water, can reduce noise to some extent. Just check that it will not cause splashing over the edge of the tank.
first thing is to look at the existing valve you have. Most often the noise is due to it being old and worn out. You can repair them but the time and effort is greater than fitting a new one. The Pegler Prestex Part 2 is a very good one and solid brass. It will probably last 100 years if you change the washer and cone every 20. If that doesn't solve your problem, start looking at other causes like unclamped pipes vibrating.
The Fluidmaster is a very quiet valve, it is annoying that the manufacturer's webpage doesn't say if it is approved for connection to the mains supply; although they imply that it can be used for tanks. It probably won't last 100 years though.
You are indeed wrong, they're listed on the WRAS directory, approval number 1102083
Ta!
Weird tried 3 times before, went back on the same link and it came up :?
Regards,
footprints
