I was getting a noise when the boiler was on full flame, initial start up until temp setting was reached or if high demand, shower running heating on. It sounded worse if I slowed the circulation pump down and slightly better when I turned it up, sounded like a rumbling but only when on full flame.
After posting on the forum I had lots of helpful advice. I proceeded to drain my system, fit a new magnetic filter, refill the system and dose with sentinel x400 x4 which I circulated for 2 weeks, cleaning filter periodically. I then drained the system completely again, refilled and drained a further 4 times before fitting a new grundfos ups3 circulation pump, refilling and dosing with inhibitor x4 and noise reducer x4. System had been almost silent since 17th Feb but last night I noticed a slight rumble again when on full flame?
Any ideas, I don't understand how it's been perfect since I've done the work and now started agai ? The only thing I've done last couple of days was flush magnetic filter?
(I have a 180l flowmax thermal store, vaillant ecotec plus 418 boiler 7yrs old and 19 rads, water is red hot, radiators are hot top and bottom, two grundfos circulation pumps, one circulating from store to boiler abs back and another circulating around rads when required)
