- Joined
- 31 Jan 2008
- Messages
- 5
- Reaction score
- 0
- Country
Hello all,first post here on what looks an excellent site.
Boiler is a Glow Worm Spacesaver RF wall hung in downstairs kitchen.
House is bog std 3 bed semi.
System has performed faultlessly for years but in past couple of months (Oct 2007) has had a worsening symptom.
On first startup each morning the system exhibits a selection of noises as if one had turned on the water supply into an empty tank.
As the boiler ignites and the motor starts turning one may hear a selection of Gurgles,Whooshes and assorted other amplified swallowing sounds...GULLLLLP....(Hope that`s descriptive enough)
Initially these sounds only persisted for perhaps 30 secs,but since October last they have been remaining sometimes for up to 10 minutes.
The general performance of the system remains excellent with no drop in heat output.
The only attempt I have made at a fix involved bleeding the only sensitive radiator on the system,located in the box room which occasionally requires a bleed to get it fully operational (once per season ).
The circulation pump (Wilo) is in the upstairs airing cupboard along with the hot-tank and much assembled clutter .
