Another noisy boiler
Discussion in 'Plumbing and Central Heating' started by scamper, 9 Dec 2003.
  1. scamper
    scamper
    9 Dec 2003
    2
    Thanks Received:
    Country:
    Like most of the people here I have a noisy central heating system and boiler.
    The boiler we have is an Ideal Classic and it's making horrendous popping and knocking noises as though the water is boiling. Not only this but when the thermostat kicks in there is often a whoosh of what sounds like water or air accompanied by a knocking/creaking noise in the pipes near the boiler. Also in the airing cupboard the pump makes a lapping noise as though there is air or water in the pipes there as well.
    The house is only 5 years old and it never made this noise originally but after a couple of years the noise started and is getting worse. I am running the system using the middle setting on the pump and 5 out of 6 on the boiler and it's driving a 4 bed house with about 12 rads. All radiators are working and hot. Sorry but I can't explain any more what type of system it is.
    I originally drained the system a couple of years ago on the advice of a plumber who reckoned there was a lot of sludge in the system. I've recently had British Gas around to service the boiler and they replaced the pump. They've since been back and put something in the header tank to quieten the boiler but it doesn't seem to have worked.
    Anybody got any other ideas as the noise is driving me mad?
  2. ChrisR
    ChrisR
    24 Jul 2003
    24,299
    Thanks Received:
    1,407
    London
    Country:
    Check that water isn't "pumping over" in the small tank, ie out of the vent over it. ALso see
    this
  3. Sponsored Links
  4. ollski
    ollski
    8 Oct 2003
    7,092
    Thanks Received:
    544
    Bristol
    Country:
    probably descaler in your header tank are you in a hard water area?
  5. scamper
    scamper
    9 Dec 2003
    2
    Thanks Received:
    Country:
    Very hard water area. Perhaps I'll give it a try.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
