Just converted an open-vent CH system into a closed system, and split into two zones whilst I was at it.
Currently, when just one zone is on, the radiators on the other zone start heating up - this is due to the first rad in the second zone being pressurised by its return pipe - this then pressurises the second zone supply, causing the others to come on. Seems that using a common return with the joins all over the place is the cause.
Fitted check valves onto the returns from rads in zone 2 - problem solved, not able to pressurise on the return line. However, they make a lot of noise if zone 1 is on at the same time. Anyone any ideas how to solve the problem?
