Hi
I have a GW 18hxi, installed in a conventional open system in my 3 bedroom house. The boiler is in what used to be the garage, with the flue going vertical through the flat roof, with termination kit. It's been fitted about a year.
The boiler emits what can only be described as a howl from the flue on initial fire-up from cold, lasting a few seconds. It can be heard all over the house, and even 2 doors down the road ! Once running, all seems OK.
The engineer thought it might be high gas pressure, and he has checked that, but it's nigh-on the 8" WG recommended. He's now at a bit of a loss.
The flue is well fixed, and I've even tried to hold it when it starts up, as I thought it might be a resonance of some sort. Didn't make any difference.
Has anybody had a similar experience ?
