Hello all!
I have a pressure booster fitted in my 4 storey house. It comes on whenever a toilet gets flushed, and whenever someone runs a tap enough to brush their teeth or wash a plate. Its quite noisy and uses electricity. Essentially it means that I am using electricity whenever cold water is supplied anywhere. I would like to reduce this usage for environmental and financial reasons.
The pressure booster (a Grundfos Home 4.5bar Booster) is currently set to a pressure of 3.5bar. Cold water pressure in the house is more than sufficient. If I were to reduce the pressure on the booster to say 3bar, would this reduce my electricity usage? Would I have to make any other changes to the plumbing, for example, adjust any valves? Also, would it reduce the frequency with which the device functions?
I am assuming that as the booster is required to maintain pressure, lowering set pressure might save some electricity but would not reduce the frequency of the booster's functioning.
Thanks for your opinions.
