Can anyone help.the cold water tap in the kitchen is so noisy when i turn it on,if i turn it on full the noise stops but the noise before getting to that point is deafening,any suggestions please.
May be the jumper inside the tap vibrating. Worse with very high mains pressure.
Try turning down the main stop cock, or next take the tap apart and grease with silicone grease and rewasher, or next change the tap, or next fit a pressure reducing valve in the mains pipe, having git your mains pressure tested. (Gauge is £10)
Hi ChrisR, it's just a flow regulator, works like the ones in combis. It's Reliance's official name in their catalogue. It's a bit posh too as it has has an isolator so you can change the regulator. see www.rwc.co.uk part no. SERV 961 190 and a few others. Cost around £10.
