I bought a cheap basin mixer tap but returned it because it was noisy when the tap was fully open and even more noisy when it was only half open. I then purchased a brand new Bristan basin mixer, with larger bore size on the tails than those on the cheap tap. The Bristan tap was also much heavier than the cheaper tap. So I was hopeful that it would not make a noise - but it still does!
I have a combi boiler, which I believe provides a high pressure water supply? And indeed, I do get a really good shower from my standard, deck mounted bath mixer tap/shower But this tap does NOT make a noise when water turned on.
So do all basin mono taps make a noise when turned on? Or can something be done to quieten them? I've read that turning down the water pressure at the boiler's regulating valve might quieten the tap but surely that would also reduce the pressure to my shower, which would be a shame
