hi,
sorry if this is the wrong place for me or for this question - just ignore if so.
I've checked the FAQ re bleeding rads and 'How to restore the pressure in a sealed heating systems' but as a DIY phobe wondered if anyone can help me further.
Have an Elec boiler and currently running OK but 2 of 5 rads are cool at the top. This time last year I bled a couple of them and the boiler shut down.
I had an engineer out (landlord pays for it) and it was fixed, he said the water pressure (I think) had dropped too low.
I've had a look on here at various threads but want to check before I try bleeding the rads again in case the boiler stops and I have to get an engineer out again.
If after I bleed the rads the boilers stops again how do I add water or water pressure back.
Is it the black tap in this pic I've taken - http://i51.tinypic.com/i1flhk.jpg
It's dark - so hard to see the pic well - sorry.
The connection it's on is also here - wider pic - http://i54.tinypic.com/2n21yl5.jpg
The pressure shows currently as - http://i56.tinypic.com/wbewe9.jpg
I'm not sure what the black and red dials indicate so if anyone can say what each is?
Question is really, if I bleed rads and it stops the boiler do I just need to turn the black tap from my first pic and if so until what point, am I checking the red or black dial from pic 3 and at what point should I turn the tap off
