Non return valves
26 Feb 2018
I’ve been having a look at my plumbing and I have noticed there are no non-return valves fitted on the water system anywhere in the property
I have an outside tap and washing machine valves, should these have non-return / check valves fitted?
The property was renovated in 2002 should they have been fitted?
Outside tap should have a double check valve on it's supply.
Some have the check valves built in to the tap, so not a separate device in the plumbing pipework. How easy it is to tell the difference is not my expert field.
These types of outside tap don't comply any more and there should always be separate check valves.
To identify, the tap will have a small nut underneath the tap just in front of the point where it's screwed into the wall elbow and if you look in the spout you will see a white plastic valve.
the tap doesn't have a check valve, all the tap has is a isolating valve
Should I fit a tap with one?
was it common or ok for them to be fitted without a check valve?
It is common but it isn't right. Is it going to kill you, probably not and you aren't going to end up in jail but if for any reason the water and bacteria in that hose gets its way back into your mains water then that's what you and your neighbours could be drinking.
Ultimately it' s your choice
I wasn’t aware that it was needed until the other day. The tap was fitted before I moved in.
Would replacing the tap with one fitted with a double-check valve would be ok?
Also, my bathroom mixer tap does not have any check valves the only check valve on the property is fitted to the combi boiler filling-loop!
What would be the best course of action?
The standard these days is to have a check valve on the incoming mains, that's to protect the external mains. There should still be a check valve on any outlet that may be in danger of becoming contaminated, hence the outside tap requirement.
If the outside tap freezes it will invariably burst the check valve, that's why they aren't approved any more and an inline internal once is specified.
Why would it have been done incorrectly, save cost, poor workmanship or not required when the installation was done?
I reckon it was done around 2002 or slightly earlier
Possibly by someone who didn't know any better or couldn't be bothered, cost is minimal. It was certainly a requirement 20 years ago but the integrated check valve tap may have been acceptable then but the tap has been replaced since. Who knows TBH.
Resurrecting an old thread :cool:
We lost water pressure upstairs this morning. Downstairs was fine. I have found a non-return valve fitted to the water pipe feeding upstairs. The downstairs water tees off before the non-return valve. I can't think why there would only a be non-return valve for just the upstairs water?
Anyway, the non-return valve is sticking and affecting the water pressure upstairs.
I was going to replace it, but then thought, why don't I just do away with it. Is it needed?
