Non tapered board - can I just joint fill and paint it
7 May 2015
Nottinghamshire
Hi
I can't see the difference between tapered / square edge board... why can't I use square edge and just joint fill and then paint...i.e. not skim it ?
Is this OK?
24 Jan 2011
Surrey
Because square edge are butted together, so when you start to fill it, there is not enough room/space to actually put filler in, so there is nothing to hold it
secondly, tapered leaves enough room to make the transition between one board and the other. so when the boards are not completely level to each other- taped edge will compensate for that
