Not pushing a push fit fitting far enough in
4 Apr 2010
Humberside
If you dont push a fitting all the way home will it leak straight away? Or suddenly blow off later?
How long is a peice of string?
What's he problem you have? If it has not gone fully home just push it in further and then give it a tug to check it's firm.
Most fittings have the gripper first so once you've cleared that the tube should not blow out. However if the tube isn't fully inserted through the internal o-ring then it'll generally leak immediately.
If the tube is scratched on the outer wall, by say dragging along the floor, then there is little chance of the o-ring managing to give a perfect seal. You then run the risk of "slow" leaks, either immediately or at some future date.
Most, if not all, fittings have a mark on their outer body to indicate the depth of insertion required. Fitting instructions generally state that you mark the tube with a pencil in accordance with this mark and then insert until the pencil mark aligns with the end of the fitting. It's a simple quality assurance measure that you ignore at your peril.
Full insertion also helps support the tube within the fitting from distortion due to any side-pull forces that the tube and fitting may be exposed to. Such side pulls can encourage leaking.
Inserts are also essential to ensure the tube is prevented from collapsing and so negating the work of the 0-ring seal.
Agreed.
The Grey Polyplumb fitting is the older style of "O" ring first grab ring second, this design is more prone to installer error, where the pipe can blow off if not fully inserted.
It's good practice to either mark the insertion depth on the pipe with a pencil or use the marks printed on some makes of pipe.
The new Hep2o system has a unique "in4sure" joint recognition system, so you can tell when the pipe is fully inserted.
