Hi all
I am currently preparing my garage in advance of having a garage conversion carried out. I have striped the ceiling of plasterboard ready for downlighters to be installed and a new hot water supply from the airing cupboard above.
I left the plumber to connect up to to a hot water pipe in the airing cupboard which he did with no problem but when I looked he has removed a 22mm notch (more liked hacked away) in the underside of one of the joists to take the pipework above the ceiling level. I have 8inch joists and know that a notch this size is fine in the top but what about underneath? I've also checked that is in the first third of the joist which is ok.
What should I do? Will the building inspector find it a massive problem? The notch looks small in comparison to the depth of the joist and its the last joist before the outside wall so little weight above. Any ideas? Or will it be ok?
Mark[/quote]
Mark[/quote]
